Hi, I am working in a SPI communication with a zynq FPGA as the master, I am using the SPI IP block (standard SPI) and sending the data from the zynq 's ARM, in the examples provided by xilinx for the slave I can read this:
* The SPI device is a slave by default and the clock phase
* have to be set according to its master. In this example, CPOL is set
* to quiescent high and CPHA is set to 1.
Status = XSpiPs_SetOptions((&SpiInstance), (XSPIPS_CR_CPHA_MASK) | \
(XSPIPS_CR_CPOL_MASK));
if (Status != XST_SUCCESS) {
return XST_FAILURE;
but in the example for the master SPI they never mention the CPOL or CPHA in the config:
* Set the Spi device as a master
Status = XSpi_SetOptions(SpiInstancePtr, XSP_MASTER_OPTION |
XSP_MANUAL_SSELECT_OPTION);
return XST_FAILURE;
and in vivado block diagram I cant find either the way to change this options
how could I set this options?
thanks
