bharaini
How to display the data in BRAM of Zynq Ultrascale+ through ethernet(RJ45) using Hercules Setup Utility
I have loaded a coe file in the Block RAM in Xilinx Vivado using the the Zynq Ultracale+ ZCU102 board. Then lauched the SDK through LwIP Echo Server. Now how do I access the BRAM data through the ethernet and display through the Hercules Setup Utility.
What are the changes that I have to do in order get the BRAM data.
Thank you.
