How to get the data received in Lwip
I using PPC440 and ISE 13.1 running on Windows Xp
I want to transmit data from/to a host PC through Ethernet connection (peer to peer),
I'm using  XPS LL TEMAC IP core and I have used the Echo server example on SDK,
The Echo server works fine,I can receive and sent back .but now I want to parse the  data of the received package which I have sent buy PC.
Is there a function provided by lwIP can get the data which I have sent ? I kown it relate to “p->payload”but I do not kown how to do with it ?
I have seen the topic "Lwip parse" but I still not get the solution, please give me some idea?
err_t recv_callback(void *arg, struct tcp_pcb *tpcb, struct pbuf *p, err_t err)
	if (p == NULL)
		tcp_close(tpcb);
		return ERR_OK;
	/* all we do is say we've received the packet */
	/* we don't actually make use of it */
	tcp_recved(tpcb, p->tot_len);
	err = tcp_write(tpcb, p->payload, p->len, 1);
	pbuf_free(p);
	return ERR_OK;
Re: How to get the data received in Lwip
Try
//int i;
u32_t *tempPtr;
/* do not read the packet if we are not in ESTABLISHED state */
if (!p) {
tcp_close(tpcb);
tcp_recv(tpcb, NULL);
tcp_error_pkt_cnt++;
return ERR_OK;
/* indicate that the packet has been received */
tcp_recved(tpcb, p->len);
tempPtr = (u32_t *)p->payload;
tcp_pkt_count++;
/* Print payload recieved from Ethernet DMA */
xil_printf("Recieved Packet. Length = %d \r\n ", p->len);
for(i=0; i<(p->len)/4;i++)
   xil_printf(" %08x ", *(tempPtr++));
 // err = tcp_write(tpcb, p->payload, p->len, 1);  don't send data out right now (don't echo)
pbuf_free(p);
return ERR_OK;
instead of u32_t *
you can try unsigned int *  also
Try
//int i;
u32_t *tempPtr;
if (!p) {
tcp_close(tpcb);
return ERR_OK;
tcp_pkt_count++;
pbuf_free(p);
return ERR_OK;
instead of u32_t *
Thanks for the reply. I have get the data !
Dear
I want to send a password from my computer to a Zynq Board.
so I want to write a code to check the sent password whether is correct or not.
could you please help me?
(actually I'm newbie to ARM, I really need your help, please)
I have another question, why did u use the below code?
@golson
Please tell me about the 'tcp_pkt_count' variable. Where have you initialzed it?
Also i tried the same code, it doesnt seem to work. Could you kindly help in telling what could I have possibly missed?
Instead of that tcp_pkt_count variable, i had done :
p=p->next;
My aim is to : read the BRAM data through the Ethernet
@golson
Kindly give info about the location of this variable 'tcp_error_pkt_cnt'.
If I'm using 'p=p->next' to get in the data, the code doesnt seem to work.
