How to handle the IRQ and FIQ interrupts?
Where can I see an example how to handle the IRQ and FIQ interrupts in Zynq 7045?
What documentation should be used? What are Zynq registers relevant?
Thank you!
Hi @ldm.eth ,
Examples for the interrupt handling are in the XSDK tool, you can try the examples.
Please refer the chapter-7 from the document UG585 for the interrupts
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Register details are under Appendix B in the same mentioned document
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Hi @ldm.eth ,
Best Regards
Abhinay PS
