wufubao
How to initialize a peripheral JESD204 in Zynq
I got a Zynq UltraScale+ MPSoC (ZCU102 board)
Like AXI_GPIO connected to the LEDs, I write REG bits according to the address defined in file "xparamenter.h" in bsp.
and the APIs provided by "xgpiops.h" drives the GPIO in PL part.
/*xparamenter.h */
/* Definitions for peripheral AXI_GPIO_0 */
#define XPAR_AXI_GPIO_0_BASEADDR 0x80000000
#define XPAR_AXI_GPIO_0_HIGHADDR 0x8000FFFF
#define XPAR_AXI_GPIO_0_DEVICE_ID 0
#define XPAR_AXI_GPIO_0_INTERRUPT_PRESENT 0
#define XPAR_AXI_GPIO_0_IS_DUAL 0
/* using the APIs provided by "xgpio.h" */
/* Initialize the GPIO driver */
Status = XGpio_Initialize(&Gpio, GPIO_EXAMPLE_DEVICE_ID);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
So I added the JESD204 IP core to the block design and connected the AXI_FPD from Zynq to s_axi from JESD204 IP core and export the Hardware to SDK. It turns out that I got a peripheral JESD204
/* Definitions for peripheral JESD204_0 */
#define XPAR_JESD204_0_BASEADDR 0xA0000000
#define XPAR_JESD204_0_HIGHADDR 0xA000FFFF
And I have no idea how to initialize the peripheral JESD204_0 because there's no such driver for JESD204
So do I need to write the driver file on my own? Or just refer to some PDF file.
If I need to write the driver, could someone told me how to find a tutorial, because I really know little about PL-PS interface. The doc that Xilinx provided are not clear enough in SDK coding, or maybe I too stupid for this stuff :-(
Thx!
Tags (3)
yawenluo16
Hi Fubao,
Did you figure it out? I'm facing the same problem as you were, don't know how/where to get the JESD204 driver to configure the jesd registers. Any documents, link or idea will be appreciated!
schumerth
Below is how I read/write to the JESD
Xil_Out(baseaddr + offset, value)  -- write
Xil_In32(baseaddr + offset)  -- read
The baseaddr is what is set in the block diagram.  The offset is what register you want to access.  Refer to https://www.xilinx.com/support/documentation/ip_documentation/jesd204/v7_2/pg066-jesd204.pdf for the register space.
Edit: wrote address, when I ment to write register.
yawenluo16
thanks a lot! you're very kind.
schumerth
Your welcome!
