How to program a DMA
Hello Forum!
I want to load data (containing a given pattern) into a ZCU111 board memory to eventually stream it as AXIS packages to feed a DAC (RFDC). In short, I want to achieve synthesysing different analog waves by uploading a digital pattern to the board.
I have questions regarding what must be done in the PS and what is done in the PL. The setup I plan to use, based on DMA doc, is the following (AXI Ethernet replaced by RFDC):
What is the simplest way to load the pattern into the memory and access it through the DMA? Is that made in the SDK script (PS)? If you know a similar example of a program that does this, that would be helpful too. It is the first time I use this module so I am confused on where to start.
Hi @nicolas05 ,
The best place to start is with the AXI DMA example C code. There are several basic programs that demonstrate how to use the AXI DMA in a loop back mode.
Once you are comfortable with the basics of loopback, it is pretty straightforward to modify the examples to just have the transmit (MM2S path) that your final design requires.
These example are built into SDK. You can also view them on GitHub.
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/axidma
An explanation of the bare metal driver is here:
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/axidma/src/xaxidma.h
Deanna
Hi @nicolas05 ,
Deanna
