mrelko
How to send/recieve data to FIR continuously? [SDK Help] [Zynq]
I have an FIR filter implemented in fabric with an AXIStream interface. I believe these parts of the design are correct. The problem I am having is pushing the data to the fabric FIR. For the Zynq it needs to go through a DMA to allow the AXIStream to work if I am not mistaken. I am using the following to test that data is being sent, however when I use the vivado waveform analysis tool, I do not see the data come through to the DMA. I followed the Vivado HLS Tutorial for streaming arrays to generate the following code, which apparently is wrong. Can someone help?
int inputData = 3, outputData = 5;
Xil_DCacheFlushRange((unsigned) inputData, sizeof(int));
Xil_DCacheFlushRange((unsigned) outputData, sizeof(int));
XAxiDma_SimpleTransfer(&axiDma, (int) inputData, sizeof(int), XAXIDMA_DMA_TO_DEVICE);
while(inputData<50){
inputData=inputData+1;
//XAxiDma_SimpleTransfer(&axiDma, (int) outputData, sizeof(int), XAXIDMA_DEVICE_TO_DMA);
printf("Out: %d \n\r", outputData);
bwiec
I would recommend referring to this code for the DMA
C:\Xilinx\SDK\2013.2\sw\XilinxProcessorIPLib\drivers\axidma_v7_02_a\examples\xaxidma_example_simple_poll.c
Also, make sure to drive tkeep and tlast correctly.
www.xilinx.com
mrelko
For a continuous stream of data coming in, what would I want to do for Tlast?  See the attacked picture for what I have currently driven.
Also, this is my HLS function.  one int in, one int out using an AXIStream..
void FIFOfir(volatile uint10 * x, volatile uint10 * y)
bwiec
You should drive it appropriately depending on how you are setting the length register in the DMA. It should be asserted for the last beat of the packet.
www.xilinx.com
houssem1992
hi all ,
I have the same problem . i want to give my input this input Data  : double eingang[5] = {1,5,6,3,2};
i receive from the beginning :
                                                           Entering main()
                                                         XAxiDma_SimplePollExample: Failed\r\n
can someone help me to corecct the code in SDK .  this is the code on sdk from the simple dma example and modified .
#include <stdio.h>
#include "platform.h"
#include "xaxidma.h"
#include "xparameters.h"
 * Device hardware build related constants.
#define DMA_DEV_ID		XPAR_AXIDMA_0_DEVICE_ID
//#define MEM_BASE_ADDR		(XPAR_PS7_DDR_0_S_AXI_BASEADDR + 0x1000000)
#define MEM_BASE_ADDR		(XPAR_PS7_DDR_0_S_AXI_BASEADDR + 0x10000000)
#define TX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00100000)
#define RX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00300000)
#define RX_BUFFER_HIGH		(MEM_BASE_ADDR + 0x004FFFFF)
#define MAX_PKT_LEN        5
#define TEST_START_VALUE    0xC
/************************** Function Prototypes ******************************/
int XAxiDma_SimplePollExample(u16 DeviceId);
/************************** Variable Definitions *****************************/
 * Device instance definitions
XAxiDma AxiDma;
int main()
	int Status;
    init_platform();
	xil_printf("\r\n--- Entering main() --- \r\n");
	/* Run the poll example for simple transfer */
	Status = XAxiDma_SimplePollExample(DMA_DEV_ID);
	if (Status != XST_SUCCESS) {
		xil_printf("XAxiDma_SimplePollExample: Failed\r\n");
		return XST_FAILURE;
	xil_printf("XAxiDma_SimplePollExample: Passed\r\n");
	xil_printf("--- Exiting main() --- \r\n");
	return XST_SUCCESS;
    XAxiDma_Config *CfgPtr;
    int Status;
    int Index;
    float *TxBufferPtr;
    float *RxBufferPtr;
    float Value;
    u32 *ptr = (u32*)0x40400000;
    int i;
    TxBufferPtr = (float *)TX_BUFFER_BASE ;
    RxBufferPtr = (float *)RX_BUFFER_BASE;
    /* Initialize the XAxiDma device.
        CfgPtr = XAxiDma_LookupConfig(DeviceId);
        if (!CfgPtr) {
            xil_printf("No config found for %d\r\n", DeviceId);
            return XST_FAILURE;
        if(XAxiDma_HasSg(&AxiDma)){
               xil_printf("Device configured as SG mode \r\n");
               return XST_FAILURE;
    /* Disable interrupts, we use polling mode
     XAxiDma_IntrDisable(&AxiDma, XAXIDMA_IRQ_ALL_MASK,
     Value = TEST_START_VALUE;
         for(Index = 0; Index < MAX_PKT_LEN; Index ++) {
             TxBufferPtr[Index] = Value;
             Value =eingang[Index];
         /* Flush the SrcBuffer before the DMA transfer, in case the Data Cache
          * is enabled
         Xil_DCacheFlushRange((u32)TxBufferPtr, MAX_PKT_LEN);
                   return XST_FAILURE;
               Status = XAxiDma_SimpleTransfer(&AxiDma, (u32)TxBufferPtr,
                       MAX_PKT_LEN, XAXIDMA_DMA_TO_DEVICE);
                   return XST_FAILURE;
         Status = XAxiDma_SimpleTransfer(&AxiDma, (u32)RxBufferPtr,
                 MAX_PKT_LEN, XAXIDMA_DEVICE_TO_DMA);
         for (i=0; i<5; i++) {
                 printf("0x%08x = %x\r\n", ptr+i, *(ptr+i));
             printf("\r\n");
         while ((XAxiDma_Busy(&AxiDma,XAXIDMA_DEVICE_TO_DMA)) ||
                 (XAxiDma_Busy(&AxiDma,XAXIDMA_DMA_TO_DEVICE))) {
             /* Wait */
         return XST_SUCCESS;
thank you
houssem
houssem1992
Hi bwies
can you help me please .
I see your posts about dma controller and i want to implement my fir filter in Zedboard .
houssem1992
Hi bwies
 i try now with another c-code to test the design . i call the ( source- , receiver- , control- ..)register of dma . I set in the memory location (MM2S)  to 1 and i want to read the output ( S2MM) . can you help me to correct this code or tell me where is the problem ? i still in this part since one week . this is my code :
//  #include <stdio.h>            // disable when program itself directly controls UART  ....  (thus no xil_printf anymore ...)
//#include "xbasic_types.h"
#include "xil_types.h"
#include "xil_io.h"
#include "xil_exception.h"
#include "xscugic.h"
//Macros
#define CHECK_BIT(var,pos) ((var & (1<<pos)))
//The DMA registers Direct Register Mode
#define DMA_BASE_ADDR 0x40400000
volatile u32 *MM2S_DMACR   	= (u32 *) (DMA_BASE_ADDR+ 0x00) ; //MM2S DMA Control register
volatile u32 *MM2S_DMASR   	= (u32 *) (DMA_BASE_ADDR+ 0x04) ; //MM2S DMA Status register
volatile u32 *MM2S_SA    	= (u32 *) (DMA_BASE_ADDR+ 0x18) ; //MM2S Source Address
volatile u32 *MM2S_LENGTH  	= (u32 *) (DMA_BASE_ADDR+ 0x28) ; //MM2S Transfer Length (Bytes)
volatile u32 *S2MM_DMACR   	= (u32 *) (DMA_BASE_ADDR+ 0x30) ; //S2MM DMA Control register
volatile u32 *S2MM_DMASR   	= (u32 *) (DMA_BASE_ADDR+ 0x34) ; //S2MM DMA Status register
volatile u32 *S2MM_DA    	= (u32 *) (DMA_BASE_ADDR+ 0x48) ; //S2MM Destination Address
volatile u32 *S2MM_LENGTH  	= (u32 *) (DMA_BASE_ADDR+ 0x58) ; //S2MM Buffer Length (Bytes)
//functions
void init_DMA_direct(); //initialise the DMA in direct mode
void start_DMA_direct(); //starts the DMA in direct mode
void set_memory(u32 addr, u32 length, u32 value); //sets a certain value into a memory range
void print_memory(u32 addr, u32 length); //prints the value of a memory range
void MM2S_ISR();
void S2MM_ISR();
void init_DMA_direct(){
	*MM2S_DMACR = 0x00000001; //enable the MM2S DMA
	*S2MM_DMACR = 0x00000001; //enable the S2MM DMA
	xil_printf("MM2S status is = %x S2MM status = %x\n\r",*MM2S_DMASR,*S2MM_DMASR); // print for debug purpose
void start_DMA_direct(){
	*MM2S_SA = 0x00100000; //setting the MM2S source addr
	*S2MM_DA = 0x00200000;	//setting the S2MM source addr
	set_memory(0x00100000, 4,0x000000001); //set the MM2S memory locations to one
	*MM2S_LENGTH = (4*4); // set the length of the MM2S and starts the MM2S
void set_memory(u32 addr, u32 length, u32 value){
	int i;
	u32 *ptr = (u32 *) addr;
	for(i = 0; i < length; i++){
		*ptr = value;
		ptr++;
void print_memory(u32 addr, u32 length){
	int i;
	u32 *ptr = (u32 *)addr;
		xil_printf("memory addr = %x with value = %x \n\r", ptr, *ptr);
		ptr++;
void MM2S_ISR(){
void S2MM_ISR(){
int main()
    init_platform();
    print_memory(0x00100000,4);
    print_memory( 0x00200000,4);
    xil_printf("Hello World\n\r");
    return 0;
my result :
the design :
it will be so great when you help me .
thanks
houssem
bwiec
Hi Houssem,
Did you flush your cache before reading back those memory locations? I don't see it.
www.xilinx.com
houssem1992
Hi bwies ,
thank you for the reply . my code is from the eample  code of xilnix . http://forums.xilinx.com/xlnx/attachments/xlnx/NewUser/16910/1/helloworld.c
in the main , i write in the memory the value 2 for all memory location  with set_memory  function .
i want to transfer this data with start_DMA_direct() .
	set_memory(0x00200000, 4,0x000000000); //set the MM2S memory locations to one
	*S2MM_LENGTH = (4*4); // set the length of the S2MM and starts the S2MM
 i flush the memory locations of MM2S and S2MM.
i receive now the inzialized value of the function start_DMA_direct().
i think that the transfer of the data  to my fir-filter is not happned . ?
int main()
    init_platform();
    Xil_DCacheFlushRange(0x00100000, 4);
    Xil_DCacheFlushRange(0x00200000, 4);
    set_memory(0x00100000, 4,0x000000002); //set the MM2S memory locations to 2
    print_memory(0x00200000,4);
    return 0;
thanks
houssem
houssem1992
i receive this result now :
no Transfer is happened i think ?
bwiec
So that's only 4 words to be transferred. Which is what it looks like in your terminal message, right?
www.xilinx.com
houssem1992
hi bwiec,
thank you for reply . i follow the programming sequence of the datasheet of the dma (Page 72 ). http://www.xilinx.com/support/documentation/ip_documentation/axi_dma/v7_1/pg021_axi_dma.pdf
for example for MM2S Sequence :
1)Start the MM2S channel running by setting run/stop bit to 1 (MM2S_DMACR.RS = 1
 2)write a valid source address to the MM2S_SA register
3)write the number of bytes to transfer in the MM2S_LENGTH register.A non-zero value causes the MM2S_LENGTH number of bytes to be read on the MM2S AXI4 interface and transmitted out of the MM2S AXI4-Stream interface. The MM2S_LENGTH register must be written last.
that what i find . sorry if i'm ignorant. If you have an example (c-code or  tutorial (i use windows 7 ) ) for the using of DMA which can help me . that will be greatly appreciated .
thanks
houssem
bwiec
Hi Houssem,
I don't follow you. It seems like the behavior is correct and you confirmed it. What is still unclear?
I do have some examples:
www.xilinx.com
houssem1992
hi all ,
i try now to test the design with the simple dma example c.code  from xilinx . my software on the ARM is never getting out of this part of the programm !
            return XST_FAILURE;
in my design i don t use the scatter gather mode . is that  a problem in the Hardware  part ?
this is a part of  the vhdl code of my simple filter :
    -- this is the process in  fir10_v1_0_S_AXIS.vhd
    -- X receive the input data from s_axis_tdata
signal a,b,c :std_logic_vector(C_M_AXIS_TDATA_WIDTH-1 downto 0):=(others => '0');
                signal y :std_logic_vector(34 downto 0 ):= (others => '0');
                signal k1:std_logic_vector(2 downto 0):="011";
                signal k2:std_logic_vector(2 downto 0):="010";
            -- Add user logic here
    begin
    -- User logic ends
          process(X,M_AXIS_ACLK)
          begin
          if (M_AXIS_ACLK='1') and (M_AXIS_ACLK'event)
          then
                  -- Verzögerung von Inputsignale bei jedem clockTakt
                      c<=b;
                      b<=a;
                      a<=X;
                      y<=(k1*a + k2*c);  -- Ausgangs Signal
                      M_AXIS_TDATA<=y(31 downto 0 ); -- Ausgangs auf die 32 Bits begrenzen
           end if ;
          end process ;
this is the c code (  without my fir block the code is working without error and the memory is copied from the transmitter to the receiver )
	if (!CfgPtr) {
		return XST_FAILURE;
	Status = XAxiDma_CfgInitialize(&AxiDma, CfgPtr);
		xil_printf("Initialization failed %d\r\n", Status);
		return XST_FAILURE;
			return XST_FAILURE;
	Value = 0;
	// TxBufferPtr[8] = {0,1,2,3,4,5,6,7 }
	for(Index = 0; Index < MAX_PKT_LEN_WORDS; Index ++) {
			Value++;
	 * is enabled
// device to DMA Transfer
		Status = XAxiDma_SimpleTransfer(&AxiDma,(u32) RxBufferPtr,
			return XST_FAILURE;
// DMA to Device Transfer
		Status = XAxiDma_SimpleTransfer(&AxiDma,(u32) TxBufferPtr,
			return XST_FAILURE;
		while (XAxiDma_Busy(&AxiDma,XAXIDMA_DMA_TO_DEVICE)) {
				/* Wait */
		while (XAxiDma_Busy(&AxiDma,XAXIDMA_DEVICE_TO_DMA)) {
				/* Wait */
		Status = CheckData();
			return XST_FAILURE;
please help
thanks
houssem
