marcelkr
How to set up the FIQ
Hey,
I'm trying to figure out how to set up the FIQ on the zynq. I'm able to produce interrupts on the IRQ_F2P and the IRQ lines successfully, but the FIQ is not working.
I'm using the BSP generated drivers for the Interrupt controller to configure the FIQ. Am I on the wrong track? Basically I'm using the provided example code to set up the interrupts and I'm triggering the line from PL via an AXI GPIO block. I checked the PL side with an ILA and it's working. So it has to be something wrong in my software.
This is how the initialization looks like
int setupIRQ(u16 DeviceId)
	int Status;
	 * Initialize the interrupt controller driver so that it is ready to
	 * use.
	GicConfig = XScuGic_LookupConfig(DeviceId);
	if (NULL == GicConfig) {
		return XST_FAILURE;
	Status = XScuGic_CfgInitialize(&InterruptController, GicConfig,
					GicConfig->CpuBaseAddress);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Perform a self-test to ensure that the hardware was built
	 * correctly
	Status = XScuGic_SelfTest(&InterruptController);
		return XST_FAILURE;
	 * Setup the Interrupt System
	Status = SetUpInterruptSystem(&InterruptController);
		return XST_FAILURE;
	Status = XScuGic_Connect(&InterruptController, XPS_FIQ_INT_ID,
            (Xil_ExceptionHandler)fiq_handler,
            (void *)&InterruptController);
        return XST_FAILURE;
    XScuGic_Enable(&InterruptController, XPS_FIQ_INT_ID); return XST_SUCCESS; }
balkris
This example design tests for FIQ interrupt. This example is designed to work with axi_timer in PL to cause an FIQ interrupt. The interrupt from axi_timer is connected to IRQF2P[15]( IRQ ID91)
The processor only operates in secure state. The interrupt is set as group 0 interrupt as secure interrupts, signaled as FIQ to processor.
HW/SW was generated by Vivado 2013.4 and tested on ZC702 production board.
Note: An Example Design is an answer record that provides technical tips to test a specific functionality on Zynq-7000.
A tip can be a snippet of code, a snapshot, a diagram or a full design implemented with a specific version of the Xilinx tools.
It's up to the user to "update" these tips to future Xilinx tools releases and to "modify" the Example Design to fulfill his needs.
Limited support is provided by Xilinx on these Example Designs.
Implementation Details
Design Type
PS & PL
SW Type
Standalone
CPUs
Single CPU
PS Features
GIC
PL Cores
AXI Timer
Boards/Tools
ZC702
Xilinx Tools Version
Vivado 2013.4
Other details
The interrupt from axi_timer is connect to IRQ ID91
Address Map
Base Address
Size
Bus Interface
axi_timer
0x42800000
64K
S_AXI
Files Provided
sourceme.tcl
 Vivado project
gic_fiq_test.c
source code
        Block Diagram
Solution
Step by Step Instructions
1. Reproduce the design by source sourceme.tcl in vivado 2013.4
2. Create HDL wrapper/ Generate Bitstream
3. Export Hardware for SDK
4. In SDK, generate an empty application, import gic_fiq_example.c
5. Program PL using the Bitstream generated by vivado
6. Run the application
Expected Results
Interrupt information will be printed as below
Thanks and Regards
Balkrishan
balkris
Design Type
PS & PL
SW Type
Standalone
CPUs
Single CPU
PS Features
GIC
PL Cores
AXI Timer
Boards/Tools
ZC702
Vivado 2013.4
Other details
Address Map
Base Address
Size
Bus Interface
axi_timer
0x42800000
64K
S_AXI
Files Provided
sourceme.tcl
 Vivado project
gic_fiq_test.c
source code
        Block Diagram
Solution
Expected Results
Thanks and Regards
Balkrishan
marcelkr
Thanks, this solved my problem :)
1georg2
hey,
i also try to connect an axi_timer interrupt to nFIQ. I'm also able to produce interrupts on the IRQ_F2P but with FIQ it doesn't work.
The example above is not clear for me because it uses IRQ_F2P again, but i want only connect the interrupt to Core0_nFIQ.  Maybe i have missed something. I  would  be grateful for any advice thx.
marcelkr
Heres are some parts of my files.
Setup the GIC:
int SetUpInterruptSystem(u16 DeviceId)
	int Status;
	 * use.
		return XST_FAILURE;
		return XST_FAILURE;
	 * correctly
		return XST_FAILURE;
	return XST_SUCCESS;
Here's how my simplified FIQ setup routine looks like:
void setupFIQ(void) {
	//struct pt_regs regs;
	/* initialize FIQ registers */
	/*regs.ARM_r8 = (long)XPAR_PS7_GLOBALTIMER_0_S_AXI_BASEADDR;
	regs.ARM_r9 = (long)XPAR_PS7_GLOBALTIMER_0_S_AXI_BASEADDR+0x04;
	regs.ARM_r10 = (long)&stop;
	set_fiq_regs(&regs);*/
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_FIQ_INT,
			(Xil_ExceptionHandler) fiq_handler,
	Xil_ExceptionEnableMask(XIL_EXCEPTION_FIQ);
The methods to set the registers are taken from the linux kernel.
Your handler should look similar to this:
void fiq_handler(void *CallbackRef)
	// do useful stuff
Call setupInterruptSystem first, then setupFIQ.
I hope this helps, otherwise report back.
Regards, Marcel
1georg2
Hi Marcel,
thank you very much for your reply. Your hint helped me a lot and now it works fine.  Another question have you ever tried to catch such an interrupt via linux?
Regards, Georg
marcelkr
Yes I did. Here's the thread about it:
http://forums.xilinx.com/t5/Embedded-Linux/Requesting-privat-interrupts-in-kernel-driver-fails/td-p/497358
Unfortunately I wasn't successful. It seems that the private interrupts aren't that easy to handle in linux as the "normal" ones.
If you are able to figure it out, I'd be glad if you'd let me know how you did it.
Regards, Marcel
dragan.topalovic
Did you try to run this example using XPAR_FABRIC_AXI_TIMER_0_INTERRUPT_INTR on cpu1? I am trying but without success. Any idea?
ouhuayu
it work well in Single CPU.my board zc706 has 2 cpu.I nterrupt may ocurr on cpu1, how can i clear interrupt.      thanks.
pvenugo
You need to set clear interrupt register. Please that particular register in user guide on interrupt controller.
Praveen
