mastercen
How to use the UART function of KC705 board?
Hi, I'm quite cofused recently trying to use the UART port to send data to the PC. Is there any official example design or instructions that introduct how to generate data package and configure the timing of both data signal and control signal? Thank you so much!
dpaul24
@mastercen,
Search Xilinx forums, search via Google.....there are numerious UART eg_designs.
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Interface-PC-and-FPGA-KC705-using-UART/td-p/818254
https://forums.xilinx.com/t5/7-Series-FPGAs/UART-problem-in-kintex-7-KC705-board/td-p/506003
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
