3008202060
How to using OCM on zedboard?
Hi all,
Could any one tell me how to write OCM from PS and read from PL?
I used to write DDR from PS and read from PL. But accessing ddr could be slow. Since my data is not that big. I want to use OCM to accelerate the process.
The screenshot below is how to used to access the data using DDR. Now, in order to using OCM, I just mapped the address from DDR to ocm(0x0000_0000 to 0x0003_FFFF). From the ps side, I write the data array to the address start from 0x0000_0000, and from PL side, I changed the read address to 0x0000_0000. I could still get the correct result, but the run-time is still almost the same. Any idea why it is not working?
Thanks a lot.
smarell
Community Manager
Community Manager
You should use ACP port to read/write from OCM. You can refer to the example design from https://www.xilinx.com/support/answers/50826.html ; in this example, we write from AXI BRAM to OCM. You can modify the application to perform a read operation from OCM to BRAM too.
pvenugo
Hi @3008202060,
Did you try via SDK to execute application from OCM?
Praveen
smarell
Community Manager
Community Manager
3008202060
Hi all,
Actually, it is working. Just the result is not what I expected. It only have 1.1X improvement when just changing from reading DDR to reading OCM.
