INFO: [Ipptcl 7-1463] No Compatible Board Interface found.
I am working on the following environment:
  • Ubuntu 16.04
  • Vivado System Edition 2018.3
I am working on implementing a RISC-V processor on the ZYNQ-702 board. The implementation is basically about having the RISC-V processor on the PL side, and it is interfaced with the ARM Core for interfacing and debugging purposes.
I am using a script that was written mainly for ZC706 after spending some time to carry out the required modifications to match ZC702 board. The script is responsible for creating a vivado project, creating and block diagram for instantiating the ARM Core then add the required RTL source.
I have not faced any error or critical warnings, however, after creating the block diagram, I had the following output:
INFO: [Ipptcl 7-1463] No Compatible Board Interface found. Board Tab not created in customize GUI
Is this a critical problem I have to address immediately? Given that I was able to successfully generate the bitstream, yet, I still have not tried it yet on the FPGA itself.
So, how should I handle this? Below is the log:
##    CONFIG.PCW_USE_S_AXI_ACP {0} \
##    CONFIG.PCW_USE_S_AXI_GP0 {0} \
##    CONFIG.PCW_USE_S_AXI_GP1 {0} \
##    CONFIG.PCW_USE_S_AXI_HP0 {1} \
##    CONFIG.PCW_USE_S_AXI_HP1 {0} \
##    CONFIG.PCW_USE_S_AXI_HP2 {0} \
##    CONFIG.PCW_USE_S_AXI_HP3 {0} \
##    CONFIG.PCW_USE_TRACE {0} \
##    CONFIG.PCW_VALUE_SILVERSION {3} \
##    CONFIG.PCW_WDT_PERIPHERAL_CLKSRC {CPU_1X} \
##    CONFIG.PCW_WDT_PERIPHERAL_DIVISOR0 {1} \
##    CONFIG.PCW_WDT_PERIPHERAL_ENABLE {0} \
##    CONFIG.preset {ZC702} \
##  ] $processing_system7_0
##   # Create interface connections
##   connect_bd_intf_net -intf_net S_AXI_1 [get_bd_intf_ports S_AXI] [get_bd_intf_pins axi_interconnect_1/S00_AXI]
##   connect_bd_intf_net -intf_net axi_interconnect_0_M00_AXI [get_bd_intf_ports M_AXI] [get_bd_intf_pins axi_interconnect_0/M00_AXI]
##   connect_bd_intf_net -intf_net axi_interconnect_1_M00_AXI [get_bd_intf_pins axi_interconnect_1/M00_AXI] [get_bd_intf_pins processing_system7_0/S_AXI_HP0]
##   connect_bd_intf_net -intf_net processing_system7_0_DDR [get_bd_intf_ports DDR] [get_bd_intf_pins processing_system7_0/DDR]
##   connect_bd_intf_net -intf_net processing_system7_0_FIXED_IO [get_bd_intf_ports FIXED_IO] [get_bd_intf_pins processing_system7_0/FIXED_IO]
##   connect_bd_intf_net -intf_net processing_system7_0_M_AXI_GP0 [get_bd_intf_pins axi_interconnect_0/S00_AXI] [get_bd_intf_pins processing_system7_0/M_AXI_GP0]
##   # Create port connections
##   connect_bd_net -net ext_clk_in_1 [get_bd_ports ext_clk_in] [get_bd_pins axi_interconnect_0/ACLK] [get_bd_pins axi_interconnect_0/M00_ACLK] [get_bd_pins axi_interconnect_0/S00_ACLK] [get_bd_pins axi_interconnect_1/ACLK] [get_bd_pins axi_interconnect_1/M00_ACLK] [get_bd_pins axi_interconnect_1/S00_ACLK] [get_bd_pins proc_sys_reset_0/slowest_sync_clk] [get_bd_pins processing_system7_0/M_AXI_GP0_ACLK] [get_bd_pins processing_system7_0/S_AXI_HP0_ACLK]
##   connect_bd_net -net proc_sys_reset_0_interconnect_aresetn [get_bd_pins axi_interconnect_0/ARESETN] [get_bd_pins axi_interconnect_1/ARESETN] [get_bd_pins proc_sys_reset_0/interconnect_aresetn]
##   connect_bd_net -net proc_sys_reset_0_peripheral_aresetn [get_bd_pins axi_interconnect_0/M00_ARESETN] [get_bd_pins axi_interconnect_0/S00_ARESETN] [get_bd_pins axi_interconnect_1/M00_ARESETN] [get_bd_pins axi_interconnect_1/S00_ARESETN] [get_bd_pins proc_sys_reset_0/peripheral_aresetn]
##   connect_bd_net -net processing_system7_0_FCLK_RESET0_N [get_bd_ports FCLK_RESET0_N] [get_bd_pins proc_sys_reset_0/ext_reset_in] [get_bd_pins processing_system7_0/FCLK_RESET0_N]
##   # Create address segments
##   create_bd_addr_seg -range 0x00001000 -offset 0x43C00000 [get_bd_addr_spaces processing_system7_0/Data] [get_bd_addr_segs M_AXI/Reg] SEG_system_Reg
##   create_bd_addr_seg -range 0x20000000 -offset 0x00000000 [get_bd_addr_spaces S_AXI] [get_bd_addr_segs processing_system7_0/S_AXI_HP0/HP0_DDR_LOWOCM] SEG_processing_system7_0_HP0_DDR_LOWOCM
##   # Restore current instance
##   current_bd_instance $oldCurInst
##   save_bd_design
## create_root_design ""
INFO: [PS7-6] Configuring Board Preset part0. Please wait ......
Wrote  : </home/user/rocket_all_respos/fpga-zynq/zc706/zc702_rocketchip_ZynqFPGAConfig/zc702_rocketchip_ZynqFPGAConfig.srcs/sources_1/bd/system/system.bd>
# exit
INFO: [Common 17-206] Exiting Vivado at Tue Jan  7 17:32:26 2020...
