IP Address -> how to change it on PetaLinux?
Hi All,
How can I reconfig IP Address on the Zynq 7045?
When I run the ifconfig, I receive the following:
eth1      Link encap:Ethernet  HWaddr 00:E0:23:00:00:00
          inet addr:172.16.10.173  Bcast:172.16.10.255  Mask:255.255.255.0
          inet6 addr: fe80::2e0:23ff:fe00:0/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:21925 errors:0 dropped:799 overruns:0 frame:0
          TX packets:1437 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:9054931 (8.6 MiB)  TX bytes:119527 (116.7 KiB)
          Interrupt:149 Base address:0xc000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
It seems that the inet addr:172.16.10.173 was configured in BSP. But now how can I force the Zynq to ask for a new IP when I connected to a new Ethernet Switch?
I tried the dhcpcd -k command, but received the following:
-sh: dhcpcd: not found
And one another question: How can I know the PetaLinux, which Zynq currently runs?
Thank you!
Re: IP Address -> how to change it on PetaLinux?
Hi @ldm.eth
Once you run ifconfig, you will get the ethernet interface like eth0 or eth1
Your ethernet interface is eth1
1. Run below command to up the ip address you desire
   ifconfig <IP> eth1 up
Best Regards
Kranthi
Mentor
Mentor
Hi @ldm.eth
Would you execute the following command on linux ?
$ dmesg | grep CPU
You can find CPU number on this output message.
Best regards,
Here is an output from the dmesg | grep CPU command:
%> dmesg | grep CPU
Brought up 2 CPUs
CPU: All CPU(s) started in SVC mode.
So, how can I know what's OS (what's PetaLinux) currently running on the Zynq?
Give the command - ifconfig <IP> eth1 up
