IP Catalog
I am trying to get a project started and I keep seeing an error when trying to add IP from the IP catalog. This is the error:
  • [IP_Flow 19-2234] Failed to initialize IP Tcl interpreter '::ipgui_xilinx_com_ip_axi_iic_2_0': can't find package math::bignum while executing "package require math::bignum"
This occured when trying to add the AXI IIC to the project. So far my project only includes the master constrain file and nothing else.
What is the math::bignum package and where do I get it?
Hi @jamaloney1 ,
In Vivado IP catalog, in which folder does the AXI IIC IP lie?
It is definetly not part of math type.
Praveen
AXI IC is located in Vivado Repositpory/Embedded Processing/Axi Peripheral/ Low Speed Peripheral.
