gomiz3
Illegal to place instance in LED pin on Microzed 7Z010
I'm trying to follow the Zynq design from scratch tutorial ( http://svenand.blogdrive.com/archive/177.html#.U7Vwu_l_s68 ),
but with a microzed board insted of a Zedboard.
I modified the code so only one LED signal is created , when i try to conect it to the board's LED pin (B14) it doesn't show up as a choice, if i write it down the following error message comes up:
Illegal to place instance LEDS_OBUF[0]_inst on site B14. The location site type does not match the instance type. Instance LEDS_OBUF[0]_inst belongs to a shape with reference instance LEDS_OBUF[0]_inst. Shape elements have relative placement respect to each other. The invalid location might results from a constraint on any of the instance in the shape."
I have also tried to attache the pin writing in the constrains file, but it doesn't work.
I would appreciate any help.
Tags (2)
htsvn
Would that be possible to attach the design for further debug?
--Hem
gomiz3
Yes, sorry that i don´t know what is needed to debug so i attached the whole project.
Tags (2)
