Image enhancement pixels wrong at start of frame
i'm using the image enhancement with dynamic active size configuration (Vivado 2014.4).
I see that the first 3 pixel of a frame belong to the previous frame.
In the attached image, i first configure the image enhancement to do a 720x576 frame
then i reconfigure to do a 60x45 frame.
In the figure the blue bus is the output from image enhancement core. The first pixels belong to the first blue frame (c034-7034)
If i enable the bypass option, data are correct
I'm the only experiencing this issue?
I also encountered this problem recently. Have you solved it?
If you have solved it, can you tell me the solution to it?
Thanks!
Hi all!
I recently upgraded to Vivado 2014.2 but this problem seems unresolved, i see that a similar problem with Active Size was resolved (AR# 60173), but i have the same effect as before, maybe is a different problem...
I didn't insert an analyzer this time, but the effect on screen is the same as before, could you resolve this?
There is any chance that this problem will be corrected in the next Vivado release?
I have this problem also with 2019.2, really bad
