bla32
Implementing the keyboard using the ps/2 port
Hi all.  I'm an electronics engineering student and I'm currently taking an Advanced Digital Design course.  I need to implement keyboard interface for my project.  I'm using the virtex II pro development board.  My question is, where should I begin?  I'm new to the EDK and ISE and so I'm not too sure how i would implement this module.  So far I've added the microBlaze to my design along with all the necessary parts to support it.  I've thought about using the GPIO and have it connected to the PLB and PS/2 but not too sure on how I would approach that.  Any information would be much appreciated.  Thanks.
-Alaire
bla32
After some research i've managed to instantiate the ps/2 ip and updated the .ucf file accordingly.  my question now is, what are the proper steps to intialize the ps/2 in the .cpp file.  i plan to use interrupts.  i've also read through the documentations in the xps2.h file but the explanations are vague.  thanks.
-Alaire
bla32
so i've got the ps/2 port all set up and was able to get polling mode working.  it prints the scan code to the hyperterminal.  i'm trying to implementing using interrupts now and its giving me a really weird error.
microblaze_enable_interrupts' was not declared in this scope
any ideas why this is occuring?  i'm assuming it might be one of the header files i'm missing?
mcgett
These questions should be posted in the Embedded Processing forums for the right audience.
joshual
If you want to use interrupt, you should register it in MB first, refer to the xapp778 about interrupt
