Increasing RS232 baud rate gives me just zeros
hello everyone,
intro:
I work with atlys board. using Microblaze processor. Using xilinx EDK and SDK as tools.
For an image processing purpose, I designed a custom coprocessor with FSL bus, which gets a (4,4) pixel window of an image from microblaze and applies a filter on it ,then sends it back to microblaze.I iterate the window on image to apply filter on all of the image.
I put the original image as a header file in C code. And use RS232 to send the resulted image from board to computer. The resulted image is a matrix of numbers between 0 and 255
First I used RS232 with baud rate 9600. it worked perfect and gives the resulted image to computer. the only problem was that the speed of sending image was too low.
problem:
I went back to edk, changed RS232 baud rate to 19200 and regenerated everything. it also worked with 19200. but still the speed was too low.
I changed the baud rate to 57600 and regenerated everything. when I tested the design, IT GIVES THE ALPHABET CODES CORRECT BUT THE MATRIX IS ALL ZEROS.
for example main part of my C code is like:
xil_printf("hello");
print("Hello World\n\r");
MYCORE_SelfTest();       //the custom IP works here
xil_printf("printing final image...\r\n\r\n");
for(i=0;i<img_size;i++){
for(j=0;j<img_size;j++){
sprintf(out,"%d ",image_res[i][j]);
print(out);
print("\n\r");
and it gives me:
helloHello World
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
it's completely ridiculous! I don't know what is the relation between baudrate of RS232 and work of the FSL coprocessor.
If the problem is with baud rate, why the words are correct and just numbers are zero. if the problem is related to FSL coprocessor, why it works for slower baud rates!!!
please please help me!!
Do not go gentle into that goodnight. Rage, Rage, against the dying of the light!
Found it myself,
it is a bug in EDK. I didn't get why but, possibly it doesn't perform required changes when you change the baude rate through the system assembly view. For a safe and confident change in baude rate you must start a new project and set the baud rate at the first of project wizard.
My further tests(commenting the filter part and sending orginal image to RS232) has turned out that when baud rate is high the FSL core just sends zeros!! SO RIDICULOUS!!
somebody help me!
Found it myself,
