diverger
Interface to a 3-wire SPI using Zynq-7's SPI at PS side
I need to interface to a PGA with 3-wire SPI, SCK, SDIO, and CS. I know Zynq-7 has two full-duplex SPI at PS side, that is, 4-wire SPI. I wonder if the hardware and SDK support the 3-wire SPI?  I'm now considering connect both MISO and MOSI to the SDIO pin, when read data, temply disable the MISO, does the SDK support this?
hayk.petr
How about putting buffer, something like:
  IOBUF #(
    .DRIVE(12), // Specify the output drive strength
    .IBUF_DELAY_VALUE("0"), // Specify the amount of added input delay for the buffer
    .IFD_DELAY_VALUE("AUTO"), // Specify the amount of added delay for input register
    .IOSTANDARD("DEFAULT"), // Specify the I/O standard
    .SLEW("SLOW") // Specify the output slew rate
  IOBUF_inst (
    .O(MOSI), // Buffer output
    .IO(SDIO), // Buffer inout port (connect directly to top-level port)
    .I(MISO), // Buffer input
    .T(CTRL) // 3-state enable input, high=input, low=output
// End of IOBUF_inst instantiation
