Interrupt Trigger Type - Double trigger
I'm studying on button interrupts. I want to trigger the function only rising edges. Although I have added the following line to my code, the button interrupt function triggers two times with one button press.
XScuGic_SetPriorityTriggerType(&intc_instance_ptr, INTC_INTERRUPT_ID_1, 0xA0, 0x3);
How can I solve this problem? I cannot realize the reason for this problem.
Hi @kaanibis
Switch de-bouncing logic is required in the hardware to avoid two or multiple interrupts for a single button press.
Even though you make the changes in the interrupt handler this may not work as there is no de-bouncing logic.
My recommendation is to go for the level triggering instead of edge triggering.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
