clem_g
Interrupt routine
I wish to implement a timer interrupt without using the xilinx driver for the PPC processor Virtex4 FX. EDK 9.1 used to build hardware with 32 bit interrupt timer. I would have thought it trivial to write and load an interrupt service routine which calls an external function and returns. What is required is the int_service_routine(), function_to_load_it( (int_service_routine)) and intEnable() and intDisable(). Can anyone point me in the right direction for an example of this.
Clem.
Chadn_na
I am not sure if this is really what you are looking for but XAPP 778 provides examples for setting up ISRs.
jeffrey.johnson
Voyager
Voyager
Here is an online tutorial for developing a timer peripheral with interrupt capability. It walks you through all the steps, with screenshots and source code.
Timer with Interrupts
I hope this helps.
Message Edited by jeffrey.johnson on 01-21-2009 06:01 AM
centaur19
Clem,
If you check the EDK install, there is an example that does just what you are trying to do. There is a system created with Virtex 4 FX, PowerPC and timer.
<9.1i EDK_Install>\EDKexamples\Virtex4_PPC_Example_9_1.pdf
HTH
hjt_on_razer
Here is a little code snipit using the PPC PIT timer
    /* Initialise the interrupt vector table*/
    XExc_Init();
    /* Register PPC405 timer interrupt handler */
    XExc_RegisterHandler(XEXC_ID_PIT_INT, (XExceptionHandler)timer_interrupt, (void *)0);
    /* initialise the PIT timer to interrupt every 1 second */
    XTime_PITSetInterval(ONE_SECOND_TICK);
    /* clear all the timer status register bits */
    XTime_TSRClearStatusBits(XREG_TSR_CLEAR_ALL);
    /* set to auto reload so always interrupts at same time */
    XTime_PITEnableAutoReload();
    /* clear any pending PIT interrupts */
    XTime_PITClearInterrupt();
    /* enable the PIT interrupt */
    XTime_PITEnableInterrupt();
void timer_interrupt (void *baseaddr_p)
    XTime_PITClearInterrupt();      /* clear any pending PIT interrupts */
/* perform required actions here */
Hope that helps
