Is it possible just to have secure PL?
I run Petalinux and configure/reconfigure my PL by simply cat the filename in a shell script. It works great, however I have been asked if we protect the IP by encrypting the .bit file. I don't want to do a secure boot, just secure the IP in our logic. Is that possible and if so what is the best way?
I am using a Zynq 7015 and boot from the SD card
Yes, ug585 says: "In all devices, the PL bitstream, which contains sensitive customer IP, can be protected with 256-bit AES encryption and HMAC/SHA-256 authentication to prevent unauthorized copying of the design. The PL performs decryption on the fly during configuration using an internally stored 256-bit key. This key can reside in battery-backed RAM or in nonvolatile eFUSE bits."
Thanks for that
