fzlorenzo
Issue with writing anything on a register
I made a custom AXI multiplier code that uses a longer logic than usual. When I try to enter a value into the register for my inputs and try reading it, I could only get DEC0DE1C as the output. Could someone please point me to the right direction or at least tell me what I'm doing wrong? My SDK code is:
//NAME:
//  main.c
//PURPOSE:
//  This C file is meant to be built with the Xilinx SDK and run as an
//  ELF file on a Microblaze processor.
//AUTHOR:
//  Lance Simms
//  Note: Code uses Xilinx examples included with Vivado.
//DATE:
//  01/09/17
/***************************** Include Files *********************************/
#include "xparameters.h"
#include <xil_printf.h>
#include <stdio.h>
#include "xil_exception.h"
#include "xuartlite.h"
#include "xintc.h"
#include "c6288.h"
/************************** Constant Definitions *****************************/
 * The following constants map to the XPAR parameters created in the
 * xparameters.h file. They are defined here such that a user can easily
 * change all the needed parameters in one place.
#define UARTLITE_DEVICE_ID      XPAR_UARTLITE_0_DEVICE_ID
#define INTC_DEVICE_ID          XPAR_INTC_0_DEVICE_ID
#define UARTLITE_INT_IRQ_ID     XPAR_INTC_0_UARTLITE_0_VEC_ID
#define c6288_BASE_REGISTER		0x44a00000
 * The following constant controls the length of the buffers to be sent
 * and received with the UartLite device.
#define TEST_BUFFER_SIZE        500
#define LED_CHANNEL				1
/************************** Function Prototypes ******************************/
u32 *baseaddr_p = (u32 *)c6288_BASE_REGISTER;
int SetupUartLite(u16 DeviceId);
int SetupInterruptSystem(XUartLite *UartLitePtr);
void SendHandler(void *CallBackRef, unsigned int EventData);
void RecvHandler(void *CallBackRef, unsigned int EventData);
static int c6288_controller(u32 iner);
/************************** Variable Definitions *****************************/
 XUartLite UartLite;             /* The instance of the UartLite Device */
 XUartLite_Config *UartLite_Cfg; /* The instance of the UartLite Config */
 XIntc InterruptController;      /* The instance of the Interrupt Controller */
  * The following buffers are used in this example to send and receive data
  * with the UartLite.
 u8 SendBuffer[TEST_BUFFER_SIZE];
 u8 ReceiveBuffer[TEST_BUFFER_SIZE];
 /* Here are the pointers to the buffer */
 u8* ReceiveBufferPtr = &ReceiveBuffer[0];
 u8* CommandPtr       = &ReceiveBuffer[0];
  * The following counters are used to determine when the entire buffer has
  * been sent and received.
 static volatile int TotalReceivedCount;
 static volatile int TotalSentCount;
int main()
	//Variable definitions
	int Status=0;
	long i=0;
	u32 iner = 0x44;
    //Set up the UART and configure the interrupt handler for bytes in RX buffer
//	Status = SetupUartLite(UARTLITE_DEVICE_ID);
	//Get a reference pointer to the Uart Configuration
	UartLite_Cfg = XUartLite_LookupConfig(UARTLITE_DEVICE_ID);
	xil_printf("Resetting Receive Buffer. Please enter a new command!\n\r");
	//Print out the info about our XUartLite instance
	xil_printf("\n\r");
    xil_printf("Serial Port Properties ------------------\n\r");
	xil_printf("Device ID : %d\n\r", UartLite_Cfg->DeviceId);
	xil_printf("Baud Rate : %d\n\r", UartLite_Cfg->BaudRate);
	xil_printf("Data Bits : %d\n\r", UartLite_Cfg->DataBits);
	xil_printf("Base Addr : %08X\n\r", UartLite_Cfg->RegBaseAddr);
	xil_printf("\n\r");
	*(baseaddr_p+0) = 0x00020003;
	xil_printf("Wrote: 0x%08x \n\r", *(baseaddr_p+0));
	xil_printf("%x\n", iner);
	Status=c6288_controller(iner);
//	while(i==0){
//      //Print out the current contents of the buffer
//      xil_printf("\n\r");
//      xil_printf("Options ---------------------\n\r");
//      xil_printf("Enter 32 bit input: \n\r");
//      //Check to make sure there is a new command to run
//      while (ReceiveBufferPtr <= CommandPtr){};
//S
//        iner = *CommandPtr;
//      if (*CommandPtr == 'x'){
//        CommandPtr++;
//        xil_printf("exiting");
//        return Status;
//      else {
//    	xil_printf("%x\n",iner);
//    	Status=c6767_controller(iner);
//      //Increment to the next command
//      CommandPtr++;
    //End of program
	return Status;
* This function does a minimal test on the UartLite device and driver as a
* design example. The purpose of this function is to illustrate
* how to use the XUartLite component.
* This function sends data and expects to receive the same data through the
* UartLite. The user must provide a physical loopback such that data which is
* transmitted will be received.
* This function uses interrupt driver mode of the UartLite device. The calls
* to the UartLite driver in the handlers should only use the non-blocking
* calls.
* @param	DeviceId is the Device ID of the UartLite Device and is the
*		XPAR_<uartlite_instance>_DEVICE_ID value from xparameters.h.
* @return	XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note
* This function contains an infinite loop such that if interrupts are not
* working it may never return.
	int Status;
	int Index;
	 * Initialize the UartLite driver so that it's ready to use.
	Status = XUartLite_Initialize(&UartLite, DeviceId);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Perform a self-test to ensure that the hardware was built correctly.
	Status = XUartLite_SelfTest(&UartLite);
		return XST_FAILURE;
	 * Connect the UartLite to the interrupt subsystem such that interrupts can
	 * occur. This function is application specific.
	Status = SetupInterruptSystem(&UartLite);
		return XST_FAILURE;
	 * Setup the handlers for the UartLite that will be called from the
	 * interrupt context when data has been sent and received, specify a
	 * pointer to the UartLite driver instance as the callback reference so
	 * that the handlers are able to access the instance data.
	XUartLite_SetSendHandler(&UartLite, SendHandler, &UartLite);
	XUartLite_SetRecvHandler(&UartLite, RecvHandler, &UartLite);
	 * Enable the interrupt of the UartLite so that interrupts will occur.
	XUartLite_EnableInterrupt(&UartLite);
	 * Initialize the send buffer bytes with a pattern to send and the
	 * the receive buffer bytes to zero to allow the receive data to be
	 * verified.
	for (Index = 0; Index < TEST_BUFFER_SIZE; Index++) {
		SendBuffer[Index] = 1;
		ReceiveBuffer[Index] = 0;
	return XST_SUCCESS;
* This function is the handler which performs processing to send data to the
* UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized. It is called when the transmit
* FIFO of the UartLite is empty and more data can be sent through the UartLite.
* This handler provides an example of how to handle data for the UartLite,
* but is application specific.
* @param	CallBackRef contains a callback reference from the driver.
*		In this case it is the instance pointer for the UartLite driver.
* @param	EventData contains the number of bytes sent or received for sent
*		and receive events.
* @return	None.
* @note		None.
	TotalSentCount = EventData;
* This function is the handler which performs processing to receive data from
* the UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized.  It is called data is present in
* the receive FIFO of the UartLite such that the data can be retrieved from
* the UartLite. The size of the data present in the FIFO is not known when
* this function is called.
* @param	CallBackRef contains a callback reference from the driver, in
*		this case it is the instance pointer for the UartLite driver.
* @return	None.
* @note		None.
	XUartLite_Recv(&UartLite, ReceiveBufferPtr, 1);
	ReceiveBufferPtr++;
	TotalReceivedCount++;
	//If we've reached the end of the buffer, start over
    if (ReceiveBufferPtr >= (&ReceiveBuffer[0] + TEST_BUFFER_SIZE)){
      TotalReceivedCount = 0;
* This function setups the interrupt system such that interrupts can occur
* for the UartLite device. This function is application specific since the
* actual system may or may not have an interrupt controller. The UartLite
* could be directly connected to a processor without an interrupt controller.
* The user should modify this function to fit the application.
* @param    UartLitePtr contains a pointer to the instance of the UartLite
*           component which is going to be connected to the interrupt
*           controller.
* @note     None.
	int Status;
	 * Initialize the interrupt controller driver so that it is ready to
	 * use.
	Status = XIntc_Initialize(&InterruptController, INTC_DEVICE_ID);
		return XST_FAILURE;
	 * Connect a device driver handler that will be called when an interrupt
	 * for the device occurs, the device driver handler performs the
	 * specific interrupt processing for the device.
	Status = XIntc_Connect(&InterruptController, UARTLITE_INT_IRQ_ID,
			   (XInterruptHandler)XUartLite_InterruptHandler,
			   (void *)UartLitePtr);
		return XST_FAILURE;
	 * Start the interrupt controller such that interrupts are enabled for
	 * all devices that cause interrupts, specific real mode so that
	 * the UartLite can cause interrupts through the interrupt controller.
	Status = XIntc_Start(&InterruptController, XIN_REAL_MODE);
		return XST_FAILURE;
	 * Enable the interrupt for the UartLite device.
	XIntc_Enable(&InterruptController, UARTLITE_INT_IRQ_ID);
	 * Initialize the exception table.
	Xil_ExceptionInit();
	 * Register the interrupt controller handler with the exception table.
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
			 (Xil_ExceptionHandler)XIntc_InterruptHandler,
			 &InterruptController);
	 * Enable exceptions.
	Xil_ExceptionEnable();
	return XST_SUCCESS;
* This function does a minimal test on the GPIO device configured as OUTPUT.
* @param	None.
* @return	- XST_SUCCESS if the example has completed successfully.
*			- XST_FAILURE if the example has failed.
* @note		None.
static int c6288_controller(u32 in)
	//Change the value of the LED accordingly
	/* Set the LED to the requested state
	XGpio_WriteReg((GPIO_REG_BASEADDR),
		  ((LED_CHANNEL - 1) * XGPIO_CHAN_OFFSET) +
		  XGPIO_DATA_OFFSET, LED_Value);
	int outer,enter;
	C6288_mWriteReg(c6288_BASE_REGISTER, C6288_S00_AXI_SLV_REG0_OFFSET, in);
	enter = C6288_mReadReg(c6288_BASE_REGISTER, C6288_S00_AXI_SLV_REG0_OFFSET);
	xil_printf("%x\n\r",enter);
	outer = C6288_mReadReg(c6288_BASE_REGISTER, C6288_S00_AXI_SLV_REG1_OFFSET);
    xil_printf("32 bit output: %08x\n\r", outer);
	// Return
	return XST_SUCCESS;
jg_bds
DECODE1C is returned by the AXI Interconnect if it doesn't know how to route a requested AXI transaction.
Check the address of the transaction against the assigned system addresses.
-Joe G.
jg_bds
-Joe G.
fzlorenzo
Is there any documentation on this? I'm following the address that Vivado had assigned for my AXI which makes me wonder if there's other reasons for me to receive this value.
jg_bds
I can't remember seeing that written formally anywhere. It's an anecdotal rule based on observations of AXI Interconnect behavior when I've munged my addresses.
-Joe G.
Hey Joe G, We just saw the suspicious looking "0xdec0de1c" show up in as a read-response in a regression test. We are nearly certain it wasn't showing up with Vivado 2018.3. It's showing up now with Vivado 2019.1 . We too looked though the docs in docnav to try to find the source of this "magic" failure code. It's not coming from our (unchanged) RTL. But it could be coming from new versions of AXI interconnect or even some Xilinx IP. Some ILA action in our future. :-) Maybe we had a bug in our logic all along, and the Xilinx IP is just now being more strict and responding as such. Yeah! Xilinx Team - it would be nice if you could chime in and point us at the source of "0xdec0de1c".  Thanks in advance. -Shep
sameer120
I am using Xilinx Vivado 2018.3 and working on Nexys Video Development Board.
In my Design I am using 16 Block Ram Controller Mapping in 64K Address Space each of 4K Address Mapping.
When I acces Read/Wirte on First & Second Block RAM controller I am able to perform Write/Read Operations Correctly.
But when i access any other Block RAM Controller I am geeting "0xDEC0DE1C" response. I have verfified my address mapping is correct.
It would be really great if anyone can help with this issue, its very critical for our Design.
Thanks & Regards
Sameer
