bishopg
LWIP Raw packet size
Is there a way to increase the maximum packet size for lwip in raw mode?  I have seen that the limit is below 2048 bytes, and I'd like to work with packets around 4096B.
golson
  I am trying to increase the Packet size also.  I do not know how to do it.  But I have trying changing LWIP parameters to see if I can send bigger packets
to the TEMAC.  Have you found a solution to your problem?
  Thank You,
Gary
