LWIP TFTP microzed
have micro zed up and working
want to run lwip...i.e. no os....
i downloaded the 1026 app.
i downloaded the freertos ...
i see all this stuff is for the zc-702..
using sdk 14.7
is there anyone out there that has gottent his dev board to work with this info/app/sw/fmw?...
hate to recreate the wheel but i have a feeling I will have to....
can someone point me to something that might getme up and running quickly...
if I can run the ethernet at 1Gig using no OS....i'd be golden...
have three weeks experience working with all this stuff (ZYNQ).....used fpga for years but not to this level...
You can use the MHS file (for zc702) provided with the XAPP1026. The only thing you will need to change is the UCF file.
Once this done, you can create the bitstream in xps, export the design to SDK, and make the software applications.
sweet....
will try out
thanks.
ok....
majorly confused
my apologies.
MHS file....i see it under the zc702_GigE folder...system .mhs.
what do I do with that file?...
tried fololwing the app note. but get all kinds fo faults not being able to locate files, etc...
my apologies for being a dummy.
