Lab4 Advanced Embedded XUP strange behavior
We are following the Lab 4 from the Advanced Embedded Labs of the Xilinx University Program. At the moment of exporting to SDK the code its not updated and, for example, the constant XPAR_FABRIC_AXICDMA_0_VEC_ID it's not found by the compiler. We replace it with XPAR_FABRIC_AXI_CDMA_0_CDMA_INTROUT_INTR, is this OK?
The problem is that the interrupt mode is taking more time than the polled mode, contrary to expectations. Could be the XPAR_FABRIC_AXI_CDMA_0_CDMA_INTROUT_INTR constant the reason? Is this the correct replace to the previous constant.
By the way, we are using Vivado 2014.4
