Licensing TEMAC Evaluation Hardware License
First of all, my apologies if this thread is not on the right place.
My problem is very simple. I want to generate an TEMAC IP Core with Core Generator. No problem with the generation itself. However, I need a license in order for the Core to be hardware evaluated. This license is free. I generated the license on appropriate place, following the instructions on the TEMAC getting started guide. I opened the "Manage Xilinx Licenses" application and added that license. I'm 100% positive that I have generated the correct license. Nevertheless, when I try to generate the core on Core Generator a warning appears saying that my license does not have hardware evaluation capability, only simulation. Anybody had the same problem?
Daniel Varela
