Line Simulation Clock Edge Has Non-Monotonic edges
Simulating the CDCE949 TI Clock Device to Zynq SoC.  I am seeing non-monotonic edges and I can't seem to smooth those out with different series resistance or impedance or distance.  Any suggestions?
Using the LVCMOS_33_F_8_PSMIO model for the Zynq receive end.
I used some other devices as receivers in the model and they don't seem to have this problem.
Professor
Professor
The position of the bump suggests to me that making that 50 ohm resistor zero ohms instead would help.  Have you tried that?
-- Gabor
I've tried 0 ohms and 50 ohms and 75 ohms and 100 ohms with combinations of transmission line impedances as well....the only thing that smooths it out is about 500 ohms :-P -- that was just a silly attempt to see what happens with a completely stupid series resistance...
I attached the 0 ohm version jpg here
Professor
Professor
I'm trying to understand why the signal at the Zynq end looks like it's in the middle of a transmission line rather than the end.  With series termination at the source, I would assume you have no termination inside the Zynq?  What is the IO standard at the Zynq end?
-- Gabor
Using  LVCMOS33_F_8_PSMIO
Professor
Professor
That sounds like an output standard ("F" meaning fast slew rate).  Did you use a generic IBIS model or did you generate it for your design using IBISwriter?
-- Gabor
I used the generic ibis model provided by Xilinx
Source termination resistor value should be:
Rs = <trace impedance> - <driver output impedance>.
So putting 22..33 Ohm instead of 50 Ohms should do the trick.
