sk16t
Linux crash when bitstream loaded to FPGA
Hi, I acknowledge this issue has been asked with some solved solutions, but I am posting this new thread because I am newbie not familiar with all the terms, and believe my situation is a bit different.
I have a blinking LED bitstream in v language, with no IP.
The bitstream is scped into Ultrascale+'s Linux. and I load the bitstream with command
bash loadingscript.sh blinky.bit
where the loadingscript.sh is below
sudo sh -c "echo 0 > /sys/class/fpga_manager/fpga0/flags"
sudo mkdir -p /lib/firmware
sudo cp ${1}  /lib/firmware/
sudo sh -c "echo ${1} > /sys/class/fpga_manager/fpga0/firmware"
The Programming does light up the LED (although clock doesn't work somehow) but more importantly Linux crashes and I lose Linux connection via SSH.
What is exactly going on?
Thank you!
p.s. I would sincerely appreciate if it could be explained in a bit easier terms due to my short experience in FPGA world.
klasha
Are there any applications or drivers running that access anything in the PL-Section while you reload the bitstream?
If so, you need to stop those from accessing the FPGA until the reconfiguration is done. Quite likely, you need to also restart/reload those drivers, so that they reinitialize their cores properly.
