MIO pushbutton configuration for gpio
Respected Sir
I am trying to do this same example design that Xilinx has provided i.e blinking of PS LED (DS50) from a PS Push Button (SW19).
embeddedsw/XilinxProcessorIPLib/drivers/gpiops/examples/xgpiops_polled_example.c
In Vivado I have only enabled MIO 0 Bank before running connection Automation , rest I have not enabled anything.
But still after pressing PS Push Button DS50 is not blinking . I don't know what I am doing wrong . Can You please Suggest Something.
Manisha Naryal
Re: MIO pushbutton configuration for gpio
Hi zuzu@123
Did you debug adding some print statements?
Here you have configured two GPIOs, may I know how you have configured?
Is an interrupt generated when you push the button?
Please share the snippet code and PS configuration if possible, will try to reproduce the issue.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
