jothiadithya
MIO
Is that possible to route PL signal to MIO pins? For example If  want to communicate with ULPI thro AXI-USB.
Jothi
umamahe
The below  forum post and AR contains related discussions
http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/PL-access-to-PS-MIO-pins/td-p/410371
http://www.xilinx.com/support/answers/51786.html
jothiadithya
So It is not possible. Correct?
Jothi
trenz-al
not directly
you can control MIO pins from PL that is OK, but you can not route them directly to PL
