dshamgar
MPSOC ultrascale+ simulation with real PS CPUs code (APU,RPU)
can i run a simulation through the vivado platform of the MPSOC ultrascale+ PS part with
real CPU code (for the RPU or APU for example) ?  which i will write of course
i don't want to run a simulation with the PS VIP. haven't found documentation on the subject.
thanks
Tags (2)
abouassi
Hi @dshamgar,
Please check the following wiki page QEMU_SystemC_and_TLM_CoSimulation.
Best regards,
Abdallah
abouassi
Hi @dshamgar,
Best regards,
Abdallah
dshamgar
thank you for the reference Abdallah!
