Max Ethernet Speed
according to xapp1026, for s3an and raw mode, i implement a design in s3e starter board. i change the original project (echo server), so i can send data in timer intervals and receive it with an application. how much speed, i can achieve in this example?
in xapp1026, and lwip performance section, there is 20Mbps for xps_ethernetlite core & spartan3e, but how can i generate large data to test this speed. currently, i send counter data in board (among timer intervals) & receive it (with application) & check it for data lost occurances. but the speed (that i have no data lost) is to low.
Re: Max Ethernet Speed
is there any idea?
This won't help a lot, but a few thoughts.
How long does your print process take ? how fast can it print out.
I know from experience that Ethernet testing is a tricky thing. I was last year trying to test a 10 G link to see what real data rate we could get on that.
I'd look at the Ethernet chips on the different Spartan boards, I know the use of DMA is a great help in getting throughput.
I'd be tempted to get a hardware test point ( use a LED ) to see with a scope the actual timings,  (code profiling )
  suggest
    when you enter and exit the print routine,
    when you enter and exit the transmit routine.
