rmelo@inti.gob.ar
Max distributed RAM in Zynq-7000
Hello. My name is Rodrigo and it is my first time here, but I work with Xilinx's FPGAs since 2006. I write to ask about the max distributed RAM in Zynq-7000. I know that it is about 25-50% of the slices (only SLICEM). In all the datasheets from XC4000 to the present, this data is in a table which summarise devices, but is not present in the "Zynq-7000 All Programmable SoC Overview". I searched in the selection guide and other documents but I not found it. Is there in some other document? If not, could somebody from Xilinx give us this information?
rmelo@inti.gob.ar
Here you are.
Vivado 2016.4 reports the Available number of "LUT as Memory":
Device LUTRAM
XC7007S 6,000
XC7012S 14,400
XC7014S 17,400
XC7010 6,000
XC7015 14,400
XC7020 17,400
XC7030 26,600
XC7035 70,400
XC7045 70,400
XC7100 108,200
Each LUT of a SLICEM can be used as a 64 bit memory, so:
Device Max distributed RAM (Kb)
XC7007S 375
XC7012S 900
XC7014S 1,087.5
XC7010 375
XC7015 900
XC7020 1,087.5
XC7030 1,662.5
XC7035 4,400
XC7045 4,400
XC7100 6,762.5
Notes:
  • 1 Kb = 1024 bits.
  • Zynq-7000S family inform the same quantity of "LUT as Memory" that Zynq-7000 with Artix logic, but the total number of LUTs is not the same.
  • Something similar occurs with XC7035 and XC7045. Same number of "LUT as Memory" but different number of total LUTs.
Regards.
austin
ds190, table 1
Austin Lesea
Principal Engineer
Xilinx San Jose
rmelo@inti.gob.ar
Where? I see Logic Cells, LUTs, FFs, BRAMs, DSPs, PCIe and AMD but not MAX distributed RAM. Or it have not SLICEMs?Table 1 of ds190
rmelo@inti.gob.ar
Sorry AMS (I don't found an EDIT button). Moreover, ds190 says: "Between 25–50% of all slices can also use their LUTs as distributed 64-bit RAM or..." so it must have distributed RAM, but the max is not said and in all the other families overview is showed (also in Zynq UltraScale+).
austin
I see the problem,
The fastest way to solve it is to use Vivado to report the resource by choosing a part, and using TCL script commands to reveal the actual number.
Austin Lesea
Principal Engineer
Xilinx San Jose
rmelo@inti.gob.ar
Mmm, I see. I can do it. I will report here when I did it. Thanks.
austin
I know,
Not the usual easy way.  But, there is only so much which fits into the data sheets.  The Zynq parts represent a real challenge: traditional users see the processor getting in the way, new users see the FPGA fabric confusing.  Its a process.
Austin Lesea
Principal Engineer
Xilinx San Jose
rmelo@inti.gob.ar
Here you are.
Device LUTRAM
XC7007S 6,000
XC7012S 14,400
XC7014S 17,400
XC7010 6,000
XC7015 14,400
XC7020 17,400
XC7030 26,600
XC7035 70,400
XC7045 70,400
XC7100 108,200
XC7007S 375
XC7012S 900
XC7014S 1,087.5
XC7010 375
XC7015 900
XC7020 1,087.5
XC7030 1,662.5
XC7035 4,400
XC7045 4,400
XC7100 6,762.5
Notes:
  • 1 Kb = 1024 bits.
Regards.
