alvaro27
Memory Controller
Hello people,
I am working on a new project  that contains a 512Mbit  HY5DU12822DTP-D43 SDRAM memory from Hynix. This part is not included in the available parts of the memory controller core mpmc in EDK. I am not  familiar with this memories but there are some other parts from this vendor included in the mpmc controller. I would like to use one of them as a reference design. What I should take into account to customize my design?
dylan
You should be able to choose a memory part named CUSTOM which will allow you to change any of the existing characteristics and memory timing parameters.  Choose another device that is somewhat similar to your memory, and then select CUSTOM.  The various settings will then become available.
dylan
alvaro27
OK, thanks.
