tdirksens
MicroBlaze - UART
Hi guys,
I would like to ask what all I need to read and write data via terminal (e.g. putty) when I use MicroBlaze?
May I want to run an application on Microblaze with a switch case and so I want to enter a case via Terminal
which will be correctly accepted? Can I use the standard UART e.g. on Zedboard/Zynq or have I to use UartLite?
Another quastion is: What could be the reason by a standard HelloWorld printf program that I just saw only some
letter for example "Hel" instead of "Hello" (Launch on SystemDebugger).
Thank you in advance
@alxtrnk
You can find examples of how to use UART (and most of Xilinx cores) on your own PC.
Normally, this is the path where the examples are (if you are using ISE Design).
C:\Xilinx\14.7\ISE_DS\EDK\sw\XilinxProcessorIPLib\drivers\uartlite_v2_00_a\examples
For Vivado I am not sure but it should be inside Xilinx directory.
Good luck!
@alxtrnk
Good luck!
tdirksens
@alxtrnk Thank you for your support!
prashantfunde91
I am using ISE 14.4.
MicroBlaze is added in my code for device Spartan3A DSP 1800
I want to use UART from Microblaze.
When i am sending data of 3 bytes or more from UART First byte received is wrong always.
 like,
09-02-2018 10:48:06.547 [TX] - 12 13 25
09-02-2018 10:48:06.558 [RX] - 89 13 25
09-02-2018 10:48:23.503 [TX] - 55 AA CC
09-02-2018 10:48:23.511 [RX] - AA AA CC
12 received as 89 means point i got is LSB is removed from original data and then MSB added as 1 and other 7 bit data is right shifted.
Even i tried to do by sending 1 byte data but still problem is observed.
During UART setting baud rate set is 115200 and same is et on Docklight.
Baud rate is correct verified in xparameters.h
So please suggest me solution to get correct data for first byte.
pvenugo
Hi @prashantfunde91,
The original post is answered and marked as accepted solution.
To get more eyes on your query and get response please do new post.
Praveen
