plip
MicroBlaze crashes on interrupt (Spartan6/simulation)
As you can see in the screenshot the MicroBlaze seems to crash/restart as soon as an interrupt (cursor) occurs. This does also happen if I use an empty ISR callback function but not if I do not register any function. What are possible reasons for this behavior?
Tags (3)
plip
Sorry for the late answer.
ISE 14.7. I am using an AXI interrupt controller with edge sensitive interrupt which is sourced by external logic.
At the moment I can not do further test as I'm dealing with another problem. Maybe you can take a look at this one, too:
https://forums.xilinx.com/t5/Other-FPGA-Architecture/MicroBlaze-Spartan6-ISE14-7-Translate-fails-after-upgrading/m-p/1130731#M39629
yzhang
You are using ISE/EDK, right? Which version?
Are you using axi interrupt controller? What is the interrupt source, any IP? What's the interrupt sensitive? edge or level?
Is C_BASE_VECTORS set 0 or other address? Can you describe the 'PC' pointer adress changes from interrupt happen till restart and the vector table reading?
plip
