06-15-2020 11:34 PM
07-22-2020 12:22 AM
Sorry for the late answer.
ISE 14.7. I am using an AXI interrupt controller with edge sensitive interrupt which is sourced by external logic.
At the moment I can not do further test as I'm dealing with another problem. Maybe you can take a look at this one, too:
07-14-2020 03:57 AM
You are using ISE/EDK, right? Which version?
Are you using axi interrupt controller? What is the interrupt source, any IP? What's the interrupt sensitive? edge or level?
Is C_BASE_VECTORS set 0 or other address? Can you describe the 'PC' pointer adress changes from interrupt happen till restart and the vector table reading?
07-22-2020 12:22 AM
