MicroBlaze program does not run in debugger
Hi.
I'm working with an AVNET LX150T Spartan-6 kit. I have been able to compile and download a very basic LED setting code. When I launch the debugger it seems to start ok (I can see the arrow pointing to the very begining of main() routine). However when I press the RUN buttom I see this message:
Error starting process.
Cannot run program "C:\JCR\workspace\quasimodo\Debug\quasimodo.elf": Launching failed
And nothing happens. There is no other failure indication, only this message.
Does anyone have a hint?
Joao
Are you able to run the elf using XMD prompt?
The procedure to do this is:-
  1. Go to EDK GUI -> Project -> Launch EDK Shell
  2. Type the command “xmd” in the shell prompt
  3. Go to the location where you have stored the bitstream and ELF
  4. Type the command “fpga -f download.bit”
  5. Once the FPGA is programmed type the command “connect mb mdm”. This will connect to the processor
  6. Type “dow executable.elf”
  7. Type “run” or “con”
--Hem
--Hem
Yes, it works this way.
Thanks a lot
