Microblaze BMM error Vivado
I am building a design with an array of microblaze processors in a generate loop but get an error when building (Vivado 2019.1)
I have assigned the elf file and bmm to the microblaze:
add_files -fileset sim_1 -norecurse $elf_location
add_files -fileset sim_1 -norecurse $bmm_location
set_property SCOPED_TO_REF mb_system [get_files -all -of_objects [get_fileset sim_1] $elf_location
set_property SCOPED_TO_REF mb_system [get_files -all -of_objects [get_fileset sim_1] $bmm_location
set_property SCOPED_TO_CELLS {{ microblaze_0 }} [get_files -all -of_objects [get_fileset sim_1] $elf_location
set_property SCOPED_TO_CELLS {{ microblaze_0 }} [get_files -all -of_objects [get_fileset sim_1] $bmm_location
But I get this error when building:
Generating merged BMM file for the design top 'design_TOP'...
ERROR::11 - Unexpected symbol '[', 'BMM info keyword - m, i, c, r, t, p, j, a, s, or f' expected.
-mf n design_TOP h DEVICE_8SERIES.WITH_BMM_INFO.TRUE_DP.SIMPLE_PRIM36.SERIES8_TDP_SP36_NO_ECC_ATTR.ram big_wrapper/design_inst/another_top/mblaze_instances[6].mblaze_wrapper_inst/mb_system_wrapper_inst/mb_system_i/microblaze_0_local_memory/output_data_bram/U0/inst_blk_mem_gen/gnbram.gnative_mem_map_bmg.native_mem_map_blk_mem_gen/valid.cstr/ramloop[1].ram.r/prim_noinit.ram c
