khachma2004
[Microblaze] How to read/write file.txt through UART?
Hi all
I'm successfull to read/write 1 byte data through UART RS232 DCE.
I'm searching method to read/write text file  through UART, someone can give me advice or sample code.
Many thanks
Khachma2004.
P/s: I'm using Spartan 3AN board
eteam00
Professor
Professor
Are you asking someone to write your code for you, and then debug it on your system for you?
Or are you looking for examples of file I/O code, to use as a guide for writing your own code?
Have you used the search engine for this website to dig up the answers to your own question?  File I/O and UARTs are probably some of the top 100 subjects for these forums.  You should be able to find all the information you want, and much more.
-- Bob Elkind
SIGNATURE:
Summary:
