Microblaze: Interrupt is not received
I wrote the attached code and did not get any interrupts.
According to the VIVADO, interrupts are running.
Can you please help ?
Thank you,
Zvika
Re: Microblaze: Interrupt is not received
What is the interrupt source device ?
I think there should be peripherals like UART, GPIO where the source of interrtupt are connected to the controller. In such case, we need to enable the interrupt for the peripharals also.
Hi @zvivered ,
The attachment is not downloading for some reason.
Yes, as asked you need to enable interrupt from a peripheral source and handle it appropriately into Microblaze.
Refer to https://www.youtube.com/watch?v=oz9VQR_5XRk .
Praveen
I had to add: microblaze_enable_interrupts ()
Thank you,
Zvika
