Microblaze SPI
I am using microblaze to configure spi, its 32 bits transfer working fine. The board used is Virtex 5. The problem is i want 24 bits transfer instead of 32 bits. How can do it in MicroBlaze? If there is an alternate solution I welcome that also. Thank you in advance.
Shreeranjani
Select transaction width to 8bit instead of 32 bit, so that if you need 24bits toggle CS for 3 byte transfer, same can apply for 32-bit also.
Venu
