Microblaze + bridge DRP + MMCM_DRP + MMCM_ADV
I have a Virtex-6 and I'm working in XPS (Xilinx Platform Studio).
I have already implemented a MMCM_ADV module (with DRP) with Clock Wizard (COREgen) and I would like to reconfigure DRP port, by using C code running on Microblaze. There is XAPP878 which describes the MMCM_DRP access procedure and has a reference design which is based on state machine, and which contains a verilog header file with all the calculation/lookup functions, of course written in verilog.
My first question is:
How can I connected the Microblaze in my design to the MMCM_DRP? I read that there is an AXI4-to-DRP bridge in XAPP1214, but when I try to import this IP into my design, an error is generated:
[quote]HDL language for the peripheral (top level) design unit drp_bridge is verilog
INFO:EDK:3391 - Create temporary xst project file:
C:\Users\utente2\Desktop\w3_802.11_EDK_v0.71_beta\pcores/drp_bridge.prj
Compiling verilog file "C:/Xilinx/14.4/ISE_DS/ISE/verilog/src/iSE/unisim_comp.v"
"C:\Users\utente2\Desktop\w3_802.11_EDK_v0.71_beta\pcores\drp_bridge.prj"
Compiling verilog include file
"C:\Users\utente2\Downloads\xapp1214-drp-bridge\source\packaged_ip\rtl\drp_bridg
e.v"
Module <drp_bridge> compiled
ERROR:HDLCompilers:26 -
idge.v" line 672 expecting 'endmodule', found 'if'[/quote]
My second question is:
What should I connect to the SADDR and the SEN ports?
Thanks in advance.
Alice
