penlaebruno
Microblaze migration Spartan6 /7 family
Hi all,
I'm working on a project were we are considering embedding a MicroBlaze softcore.
This project will be first running on a Spartan6, and will be moved eventually to a device of the 7 family (Spartan 7 very likely).
I would like to know if I should expect extra work (both software, toolchain, and hardware) when changing target device (for instance changes in the CPU behavior between the ISE and the VIvado generator)?
Best regards.
alesea
pb,
If you design uB with ISE 14.7 using AXI bus (plder ISE used PMBus), it should be seem less to go to newer nodes.  Moving to Vivado from ISE is pretty well documented.
alesea
pb,
penlaebruno
Thanks Alesea for the reply.
Indeed the plan is to use ISE14.7.
Best regards.
