NPI
I am trying to make a custom IP which I want to connect with the MPMC module. I want to use the NPI port for this, because I need a fast connection. Is there any easy way to implement this? Or do I have to build the control logic myself?
Tx in advance,
Ruben
I know it is very late to answer your question but anyway. Maybe there will be somebody else who will be looking for similar info.
As I found out by now, there is no easy way to connect custom core to NPI port of MPMC.
I think the following AR is way to start:
http://www.xilinx.com/support/answers/24912.htm
If somebody has any example or more info how to start with NPI and MPMC, except MPMC UM and above mentioned AR, please jump in!
Alex
Message Edited by alexsvet on 08-25-2008 11:11 AM
