Need Zynq AXI example
I am trying to write configuration registers in the dac_source block included in the IP Example Design for the RF Data Converter (can be found at PG269 page135) using the Zynq processor. The block is basically a waveform generator that feeds samples to the DAC.
Where can I find a getting started example for writing to a custom RTL AXI slave using the PSU?
Re: Need Zynq AXI example
You need to refer to https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1119-vivado-creating-packaging-ip-tutorial.pdf to create customer AXI IP.
regards
Praveen
regards
Praveen
