06-06-2018 09:19 AM
I am trying to get basic ethernet communication working with the AXI Ethernet Subsystem and DMA in a MicroBlaze design using a Nexys4 DDR board, I generated this design and get the following critical warnings:
I think the 12-1790 warning can be disregarded because my evaluation license is still current:
https://store.digilentinc.com/nexys-4-ddr-artix-7-fpga-trainer-board-recommended-for-ece-curriculum/
I'm not sure what is causing the other critical warnings. I have the implementation and synthesis logs attached to this post.
I created a Peripheral Tests project in SDK
and hangs at the "Running AxiEthernetSgDmaIntrExample() for axi_ethernet_0..." line:
More specifically, when I step through the program, it hangs at line 606 of xaxiethernet_example_intr_sgdma.c
I also created a lwip Echo Server example project:
But cannot connect when using Terra Term, I get a "connection refused" message on the PC side.
I also noted that the LINK/ACT and 100/10 leds do not light up on the Nexys4 DDR board while running either the peripheral or lwip SDK projects, which tells me it's definitely a hardware problem since those leds lit up on a previous hardware design using the AXI Ethernetlite on the same board.
Thanks in advance.
06-18-2018 08:05 AM
I figured out the problem. The AXI Ethernet Subsystem is not compatible with the Nexys 4 DDR, since the PHY on that board is not a gigabit PHY, so it requires a RMII interface, while the AXI Ethernet Subsystem can only support RGMII or GMII.
I purchased a nexys video board, which has a gigabit PHY that supports RGMII and is therefore compatible with the AXI Ethernet subsystem.
06-07-2018 04:07 AM
Hi @bklopp,
Please check this
https://github.com/andrewandrepowell/mic_gather_data
Best Regards,
Srikanth
06-18-2018 08:05 AM
05-06-2020 04:15 AM - edited 05-06-2020 04:16 AM
You are fundamentally wrong. AXI Ethernet Subsystem is support MMI which can be connected to RMII for the LAN8720 via the "mii_to_rmii" ip core.
