mrbietola
No input from JTAG UART psu_coresight_0
Hi, i followed the instruction to redirect STDIN and STDOUT on ps coresight.
when i open jtagterminal i'm able to see the output of my program in the terminal, but i can't send data to my program.
Is this expected?
STDIN and STDOUT are both set to psu_coresight_0 in the bsp setting
I use Vivado 2019.2 for Ubuntu 16.04
Tags (3)
mrbietola
I found that in my program i was using functions from uartlite driver to receive characters, now since the driver is DCC coresight, i need to use getchar() instead.
for writing to STDOUT i had no problem because i was using xil_printf() that maps automatically to the DCC coresight driver
Anyway getchar() is blocking so i think i need to use the low level DCC driver functions to make the call unblocking.
mrbietola
