mrbietola
OSD Graphic problem
i tried to draw boxes with the graphical controller inside the OSD.
I get good results except for some location on the screen where the box is not completely drawn...
I configured the osd to use same clock for input, outputs and axilite to avoid clock conversions inside the core
i use version 5.01a of the ise 14.4 suite
Anybody have a solution for this?
Can i import the newer version of the OSD core from Vivado in an EDK project?
debrajr
That is something we wont recommend. Wont it be possible to upgrade to Vivado?
Debraj
