kvkhekale
Openamp: Remoteproc Unable to handle kernel paging request
Hello all,
 I am trying to dual boot Xilinx-7000 CPU on CoraZ7-10 board with Linux on one Core, while bare metal application on RPU.
I have prepared bit file, hdf files from Vivado and SDK 2017.4.
According to ug-1186, I have also changed the BSP settings to include Openamp library and made -DUSE_AMP=1.
BOOT.bin and Image.ub are made from petaLinux. I can boot Linux from BOOT.BIN  and Image.ub
But following message shows up while booting, regarding remoteproc.
(Boot Sequence:)
Above image is about the boot sequence of Linux on  Zynq-7000.
"Direct Firmware Load for rproc-remoteproc@0-fw failed with error -2"
Is this causing the error further? What Can I do to load the firmware successfully?
Error OccurenceError Occurence
Also, regarding the above error, am I doing something wrong in setting up device tree?
 Attaching the device tree herewith this question:
